Back seat
troutfinder
In the center of the seat (each side respectively) there should be a black strap (it could be pushed down between the bottom and back of the seat), pull that up and it will release the bottom of the seat and allow it to fold up and forward. Now put your hand on the side of the seat back, down by the wheel well hump. Feel that lever? Pull the top of it and fold the seat back down flat. :aok:
The backs should actually be adjustable as well, using the lever, you should be able to adjust the locking angle of the seat back.
If you can't find the strap for the seat bottom, dig around in there, past the metal 'wire' that is designed to hold the strap where it is accessible, and grab the mechanism below it. If all else fails, unbolt the front of the seat and lift it up until you can see what we are talking about.
