NIssanBoston Posted October 28, 2016 Author Share Posted October 28, 2016 Retro fit a rough country xj bumper , following theexbrits guide on cutting the brackets. Had some extra support brackets made , bolted and welded to the bumper . Sent from my SM-G530T using Tapatalk 3 Link to comment Share on other sites More sharing options...
NIssanBoston Posted October 28, 2016 Author Share Posted October 28, 2016 Not to much of a gap between the headlights and bumper, got it as close as i could without running into problems fitting a winch. Heres some more photos of the mounting of the bumper. Sent from my SM-G530T using Tapatalk Link to comment Share on other sites More sharing options...
NIssanBoston Posted October 28, 2016 Author Share Posted October 28, 2016 Also, went on a local trip this past weekend with a jeep club, moderate rock climbs, lots of washouts, pathy preformed very well and was very confident of going through everything. Didnt get to many photos, but here are some i did take. Also got around to finally bolting up my winch, i didn't wire it yet as the battery i have now is very weak, i got my eyes on the yellowtop double post battery, i should have that in the next week or so. For some odd reason, i had to drill the holes bigger on the bumper , the bolt was not going through and was sitting at an angle. Everything lines up as it should now. Sent from my SM-G530T using Tapatalk 1 Link to comment Share on other sites More sharing options...
mjotrainbrain Posted October 28, 2016 Share Posted October 28, 2016 Wow, it looks really good! Could you post a link to theexbrit's guide? I can't seem to find it. Have you had a chance to use the winch yet, to tell if your bumper mounting is secure enough? Link to comment Share on other sites More sharing options...
NIssanBoston Posted October 28, 2016 Author Share Posted October 28, 2016 Wow, it looks really good! Could you post a link to theexbrit's guide? I can't seem to find it. Have you had a chance to use the winch yet, to tell if your bumper mounting is secure enough?Sure thing, http://www.nissanpathfinders.net/forum/topic/36674-xj-cherokee-bumper-mod/ No i didn't get to use my winch yet as i dont have a good enough battery to handle it, i did get pulled out with it since i had it, i see no problems so far. Winching shouldn't be a problem either. I'll update you on it though once i test it out for sure. Sent from my SM-G530T using Tapatalk 1 Link to comment Share on other sites More sharing options...
mjotrainbrain Posted October 28, 2016 Share Posted October 28, 2016 Sure thing, http://www.nissanpathfinders.net/forum/topic/36674-xj-cherokee-bumper-mod/ No i didn't get to use my winch yet as i dont have a good enough battery to handle it, i did get pulled out with it since i had it, i see no problems so far. Winching shouldn't be a problem either. I'll update you on it though once i test it out for sure. Sent from my SM-G530T using Tapatalk Thanks! Link to comment Share on other sites More sharing options...
TowndawgR50 Posted October 28, 2016 Share Posted October 28, 2016 Be careful winching from those mounting points. They are not that strong. Try incorporating the lower bumper mounts and the OEM tow points for more strength. 1 Link to comment Share on other sites More sharing options...
NIssanBoston Posted October 31, 2016 Author Share Posted October 31, 2016 Be careful winching from those mounting points. They are not that strong. Try incorporating the lower bumper mounts and the OEM tow points for more strength.Yeah i was going to add aditional metal to support winching in the future, as for now this should do. The bumper is stiff and bolted on there pretty good. It will handle winching , extra support doesnt hurt though. Sent from my SM-G530T using Tapatalk Link to comment Share on other sites More sharing options...
