Guest roadrunner2004 Posted February 7, 2005 Share Posted February 7, 2005 Hello I am looking for the Stereo amp I have a 95 pathy XE 4x4 I have called the dealer's and one said it is behind the stereo and the other one said it is under the center console ??? And dose any one know if I can make my ant wire for my Alarm longer or what would make it unlock farther away I have be right next to it to make it work ??? Roadrunner2004 Link to comment Share on other sites More sharing options...
Airrun2002 Posted February 7, 2005 Share Posted February 7, 2005 Your factory (amps) are in the back cargo area on the passenger side behind the plastic cover. Link to comment Share on other sites More sharing options...
Mr. Pickles Posted February 8, 2005 Share Posted February 8, 2005 Your factory (amps) are in the back cargo area on the passenger side behind the plastic cover. Yep, the dealer is full of crapola. You might try a new battery in the alarm remote. You can pick one up just about anywhere, even the grocery store, for a couple bucks. Link to comment Share on other sites More sharing options...
Guest roadrunner2004 Posted February 8, 2005 Share Posted February 8, 2005 Hello I hade the batt. tested and thay said it was good Do I have enef wire to move my alarm under the dash OR can I make the alarm ant. longer ???? Thanks for ever thing evre one has help me with Roadrunner2004 Link to comment Share on other sites More sharing options...
88pathoffroad Posted February 9, 2005 Share Posted February 9, 2005 Precisely how does one go about testing remote control batteries? Or did you have your vehicle's battery tested? I don't know about the stock alarm, but I do know that it's under the driver's side seat. Take your seat out and look under the carpet for the remote wire if at all possible. Yes, you can attach a longer piece of wire and run it up into the dash or wherever you want it. Link to comment Share on other sites More sharing options...
