byob Posted May 22, 2014 Share Posted May 22, 2014 (edited) So a 01 came in yesterday. This is what I see with the 4th gen Nissan Consult. This client has multiple concerns all typical with the R50's. The ign codes are typical in all the 3.5 engines and will cause the p0303. The timing dtc could be caused by low or no oil. The mas could be internal. With the proper filtration cleaning is not the option. In a perfect situation the mas will never need to be "cleaned" . This truck has 180,000 miles and has been poorly maintained. More pics of common problems coming Edited May 22, 2014 by byob Link to comment Share on other sites More sharing options...
stioc Posted May 22, 2014 Share Posted May 22, 2014 Wow, that's a lot of different codes, I wonder if they're all related to the same one culprit. I have an eternal P0505 ever since I cleaned the ICV with the idle high. It doesn't always come on after a reset, sometimes weeks go by but it eventually always returns despite my manual idle relearn multiple times. I guess I should bring it to ya for a Consult relearn Link to comment Share on other sites More sharing options...
byob Posted May 22, 2014 Author Share Posted May 22, 2014 (edited) All the dtcs are separate except for the coil and misfire. The target idle speed on mans is 625 and 700 on autos +/- 50rpms. If it keeps coming back try cleaning the throttle body and make sure the tps voltage is below .50 at idle and showing closed. No loads and no one has messed with the factory idle set screw. If all else get a new aicv. I can relearn it for nada. Here is a typical rear main leaking at idle Edited May 22, 2014 by byob Link to comment Share on other sites More sharing options...
5523Pathfinder Posted May 22, 2014 Share Posted May 22, 2014 (edited) So, did it have oil in it? I really liked using Consult. 3+ is freaking awesome and pretty quick. There are a lot worse tools out there(ford IDS, Toyota Techstream). Edited May 22, 2014 by 5523Pathfinder Link to comment Share on other sites More sharing options...
byob Posted May 22, 2014 Author Share Posted May 22, 2014 The client just bought all six coils as soon as I get the drivability done I will get to the rest. C3P has come a long way and $10,000 for the complete kit it better work well Link to comment Share on other sites More sharing options...
Karmann Posted May 22, 2014 Share Posted May 22, 2014 (edited) Wow what a mess, think it was burning oil like a lot of VQs? Edited May 22, 2014 by Karmann Link to comment Share on other sites More sharing options...
stioc Posted May 23, 2014 Share Posted May 23, 2014 The client just bought all six coils as soon as I get the drivability done I will get to the rest. C3P has come a long way and $10,000 for the complete kit it better work well $10k holy cow, I thought if I found one for under $500 I might get one but dang. Do you work at an independent repair shop or Nissan dealership? Link to comment Share on other sites More sharing options...
byob Posted May 23, 2014 Author Share Posted May 23, 2014 I am a shop foreman at a Nissan Dealership. We just bought a Toughbook c19 that cost $3500 alone. I need to buy a vi and just the basic hardware to get it running. The security card is $400 Link to comment Share on other sites More sharing options...
