madhakish Posted February 11, 2014 Share Posted February 11, 2014 (edited) I've read the TSB, but it just seems to imply the fill hole doesn't allow for a proper refill volume. My drain plug is seized so a drain and fill is out without significant work and I am beginning to hear the dreaded whine..Am I to understand that the transmission is not filled to all 5L from the factory (and none ever were?), and that one can and should fill the remaining 2L via the shifter opening regardless?If so is there any harm in adding new fluid to a stock fill that's been run for 225k miles given it's the proper yellow-metal friendly type? I've got 5L of redline in the garage but can't drain what's inside out.. Edited February 11, 2014 by madhakish Link to comment Share on other sites More sharing options...
silverton Posted February 11, 2014 Share Posted February 11, 2014 I'd take it somewhere that has an impact to remove the drain plug. As far as adding fresh fluid to old fluid it should be okay. Just make sure it's the proper GL number because I know the newer stuff will eat the bronze. Link to comment Share on other sites More sharing options...
madhakish Posted February 11, 2014 Author Share Posted February 11, 2014 I'd take it somewhere that has an impact to remove the drain plug. As far as adding fresh fluid to old fluid it should be okay. Just make sure it's the proper GL number because I know the newer stuff will eat the bronze. I've hit it with both air and electric impact guns using the 13mm attachment, as well as a 4' breaker propped up w/ a floor jack to keep it in the socket. I couldn't get it so i took it to my mechanic who also couldn't get it to budge. Maybe I'll hit it with a torch when it finally warms up enough to stay outside for more than 20 minutes.. Got the right GL, redline M/T something safe for bronze synchros etc.. Will top it off for now until I can get it loose. Link to comment Share on other sites More sharing options...
silverton Posted February 11, 2014 Share Posted February 11, 2014 I don't know much about the manual gearboxes in these trucks. Is it not the standard 1/2" square hole like most differentials are? Usually have to get a pick or screw driver to clean it out. Link to comment Share on other sites More sharing options...
Precise1 Posted February 11, 2014 Share Posted February 11, 2014 13mm square drive, it can matter. Of course adding fluid is better than ignoring it, but draining the previous fluid is the best scenario. Keep at geting it loose... B Link to comment Share on other sites More sharing options...
madhakish Posted February 12, 2014 Author Share Posted February 12, 2014 Well that was worth while! I've always felt like the transmission felt "loose".. Too much vibration, too loud, etc. Hard to explain, but it just felt odd. Added 2L of Redline M/T and took her out for a test drive and it feels soooo much smoother at speed. It feels "full". As if everything is moving in fluid vs. not. Bearing "whine" is noticeably reduced but not gone. Overall at 2500-5500 rpm things just feel more solid. Very hard to explain, definitely have to feel it to understand.. Link to comment Share on other sites More sharing options...
