noquarter89 Posted January 21, 2014 Share Posted January 21, 2014 I'll be going to the junkyard soon and I need a new set of wheels. What other Nissan wheels will fit? Will any JGC wheels fit? Link to comment Share on other sites More sharing options...
noquarter89 Posted January 21, 2014 Author Share Posted January 21, 2014 I used the search but my phone won't search just the WD21 section. Link to comment Share on other sites More sharing options...
Kyle94 Posted January 21, 2014 Share Posted January 21, 2014 chevy, toyota, and nissan wheels with 6 lugs are all the same. and jeep wagoneer wheels should be as well. Link to comment Share on other sites More sharing options...
nunya Posted January 21, 2014 Share Posted January 21, 2014 This has been covered a few times... Not all 6 lug wheels are created equal and as strait forward as Kyles post would suggest in a quick glimpse. Your lug pattern is 6x5.5, some newer nissans have a smaller lug diameter and will not work-and some have a smaller hub bore that would need modified to fit a wd21 (a couple members here have had to modify to fit xterra and frontier wheels). A 1/2 ton suspension 4x4 GM pickup/SUV (silverados, tahoes, h3s, etc...) also shares the lug pattern but again a factory wheel from one of them will need the hub bore modified to clear a wd21 hub. Some Toyota 4x4s share the lug pattern (as do other import 4x4s of the time) but some will require a new set of lug nuts to acomidate a different seating pattern. Now if one of the above mentioned has a set of aftermarket wheels, they usually have a larger hub hole to acomidate many applications Link to comment Share on other sites More sharing options...
Kyle94 Posted January 21, 2014 Share Posted January 21, 2014 sorry, when i think of getting wheels i think of old wheels. My bad. Link to comment Share on other sites More sharing options...
noquarter89 Posted January 21, 2014 Author Share Posted January 21, 2014 Thank you nunya. I did try the search but like I said I can't just search for 86.5-89 wd21's. My phone won't cooperate. Link to comment Share on other sites More sharing options...
nunya Posted January 22, 2014 Share Posted January 22, 2014 Yea, mobile searching (searching in general or that matter) can be a little "off" at times there are situations to can wander into 90-95 wd21 stuff as well for help, this is one of those situations. Now if you ask about what size tire you can fit... That's a different story Kyle, old or new "chevy Toyota and Nissan with 6 lug" is vauge and leaves a lot open. A 70s chevy wheel will have the same smaller hub bore as an 06 H3. We can't read minds so we don't know you meant old rusty aftermarket wagon wheels Link to comment Share on other sites More sharing options...
ahardb0dy Posted January 22, 2014 Share Posted January 22, 2014 Isuzu 6 lug wheels will fit as well Link to comment Share on other sites More sharing options...
