Properly Timing Engine While Assembling
DCgabel
(1996 Pathfinder LE 3.3l VG33E)
Hello, Just because I'm not a mechanic and everything I've done so far is by teaching myself or from learning from mechanics, i have a question since i'm tackling the task of a full engine rebuild and i'm at the point where I'm putting everything back together now that all the crucial parts have been replaced.
I have the valves heads all back together and I'm at the point where i am ready to bolt the head back down to the block. Is there anything i should be doing to keep everything in order to not mess up my timing? Any input would be appreciated. Thanks!
Edited by DCgabel
Just bolt them on working from the center out in a pattern. Your rockers should be off and all your valves should be shut so there's nothing to mess up anyway.
If you don't have the FSM I suggest you download one and read it.
Pg. 69 in the FSM (engine mechanical). All bolts in a center out sequence to 22 ft. lbs. then to 58 ft. lbs., loosen all bolts, again to 22 ft.lbs. With angle wrench 80-85 degrees clockwise. No angle wrench torque to 54-61 ft. lbs.
Edited by SkiBumBrian
