which wheels are engaged in 2wd ?
D21disciple
hi
my daughter has complained that her wheels are slipping in 2wd while pulling away from a stop (on wet roads, or parked on a hill with wet leaves).
i told her to give it less gas. :shrug:
the rubber on the rears is very good, while the rubber on the front is just fair (although the wear is nice and even).
i am new to pathfinders, and to 4wd, but i assumed that the rears would be engaged in 2wd ... am i correct ?
Well, that's kind of normal in 2wd for tires to slip from a stop on wet roads or leaves. Probably even more so in RWD cars, since there's no engine weight on the rear wheels. Giving it less gas is the way to go. :aok:
