How To Remove Injectors The Easy Way...
MY1PATH
Little trick I came up with, works best with R50 and WD22 Injectors but can also be used with WD21 and other nissan's if an allen key is tightly fitted into the hole on the side of the injector and then slowly pried against.
Experiences may vary in other nissan because cars like the the z32 300zx use thicker o-rings and I'm guessing they will fight you more.
Good tip, but I'd be afraid of breaking the plastic. I found a WD-40 soak, then grabbing the injector with a rag and twisting it slightly back and forth while pulling straight up worked quite well for me. YMMV...
