help with power windows
bratwurst_boy
hey guys,
i need help with my power windows. i need to relocate the switches from the door to the centre console to make way for a stereo install. so i just want to know if anyone knows what wires do what in the window switch panel. its a 99 Ti Right hand drive (ozzy model) if that makes a difference.
thanks in advance guys
Why not just cut the harness leaving some on the plug end, than just extend each wire. I guess you want to get the whole harness out of the door, you can do all your connections under the kick panel, there may even be a plug behind there that plugs into the door harness.
Just realized your probably going to use non stock switches and that's why you need to know what wire does what, my bad
Edited by ahardb0dy
