Wire diagrams for the two stock audio amplifiers in a 1993 Pathy
MrEviLDeD
First I would like to take a moment to thank everyone that has not only welcomed me in some way but also taken the time to answer my onslaught of Pathfinder questions :) Thank you!
I was wondering if anyone happened to have a wire color diagram for the connectors that connect to the stock audio amplifiers in a 1993 Pathfinder SE.
As of the time of writing I have only located the one amp that is mounted behind the dash and I will locate the second amp here soon. What I was hoping to not have to do was to brute force check the lines for speaker connection to isolate the LR, RR, etc...
Any help here would be greatly appreciated.
Your second amp will be in the rear hatch area on the passenger side. Pop off the side panel that goes above the wheel and you'll see it there. Oddly, that one is for the front speakers and the front amp is for the rear speakers.<br /><br />As for wiring try the12volt.com my buddy has a 93 though and his wiring was not anything like that, was closer to my 94.
With a little more searching I located something at
http://crutchfield.custhelp.com/app/answers/detail/a_id/6731/kw/1993%20Nissan%20Pathfinder
This seems to match out fairly well with the wiring I have seen as so far. Hope the link helps someone else as well.
Now to pull the rear passenger panel and find the front amplifier.
Cheers!
