fluid for transfer case
jdubs12
You can use either GL-4 gear oil (do not use GL-5 or dual rated GL-4/GL-5 stuff) or Dexron III ATF in the transfer case. Do not mix the two. Synthetic ATF is preferred if you plan to use ATF; I'd suggest Valvoline MaxLife since it is synthetic and has a beefy additive package. Otherwise, Amsoil MTG or Redline MT90 are great GL-4 options.
Edited by Towncivilian
