jdubs12 Posted April 18, 2013 Share Posted April 18, 2013 So i have read that a lot of ppl put jeep coils in the rear for a 2" lift....this sounds cool but I have a few questions/problems to adress before pursuing it: 1) is this hard? I have my house till may 15th then move into a condo and will not be able to do vehicle work myself anymore... 2) what were the coils exactly? 3) i have rancho rs5000 on the back...not the ones used for lifts, but the guy at NAPA said they could support a lift of 1.5 - 2 " no problem....is this risky ?4) what is required tool wise I want to do something significant to it while I have a driveway... Link to comment Share on other sites More sharing options...
Precise1 Posted April 18, 2013 Share Posted April 18, 2013 1) No. It is so easy, some people do it without spring compressors. 2) Let me find you the link... http://www.nissanpathfinders.net/forum/topic/18-rear-spring-options-for-lifting-your-wd21-pathy/ 3) No risk. I have stock length shocks and jeep coils. If you don't remove your sway bar you'll probably never know the difference, but without the sway bar, the shocks will probably limit travel. I believe it is also discussed in the link. 4) Jack, jack stands, wrenches or socket set and spring compressors (recommended) If you have what you need and a buddy to help for a bit, consider it a 2 hour job. B Link to comment Share on other sites More sharing options...
jdubs12 Posted April 19, 2013 Author Share Posted April 19, 2013 precise youre just a pathfinder god eh, thanks Link to comment Share on other sites More sharing options...
Precise1 Posted April 19, 2013 Share Posted April 19, 2013 Nope, more like dinosaur, but you are welcome. Most of it is covered, but holler if you run into trouble... B Link to comment Share on other sites More sharing options...
NorCal88 Posted April 20, 2013 Share Posted April 20, 2013 I just did it with the moog jgc coils and the only thing really is getting jack stands high enough so you can drop the axle far enought below the truck. If you dont have blocks you can just remove the wheels to get the extra drop. Link to comment Share on other sites More sharing options...
jdubs12 Posted April 21, 2013 Author Share Posted April 21, 2013 how bad is it (to crank the tbars to go up an inch) on the front suspension? or do you guys just stay an inch higher on the back? Link to comment Share on other sites More sharing options...
Trogdor636 Posted April 21, 2013 Share Posted April 21, 2013 Not bad at all. Your front may have sagged an inch if its never been touched. An alignment always helps with tire wear after messing with the suspension, so keep that in mind Link to comment Share on other sites More sharing options...
jdubs12 Posted April 21, 2013 Author Share Posted April 21, 2013 yeah - i need one anyway i went off a cliff last weekend and was dragged out sideways by 2 tow trucks.... Link to comment Share on other sites More sharing options...
Precise1 Posted April 21, 2013 Share Posted April 21, 2013 What the hell?!? The normal stance for a WD21 is slightly nose down, about .5-1.0". Measure the height to the body crease... B Link to comment Share on other sites More sharing options...
jdubs12 Posted April 21, 2013 Author Share Posted April 21, 2013 will do cheers Link to comment Share on other sites More sharing options...
