Leo94 Posted April 13, 2013 Share Posted April 13, 2013 Ok so I needed to change my dash needles from being bent and while I was installing the instrument cluster I was having abit of a hard time installing the speedo cable. I though it went in when installing the instrument cluster so I screwed everything in and put the rear end on jack stands threw it in second gear and no speed reading. I have also tried running it without the dash and I can see the speedo cable spinning on the inside, so there's nothing wrong with the cable I would think. I think the real problem is that I can't get the cable in engage with the cluster properly. Also the part that goes into the speedo came off but can go back into the cable and still spins, Is this normal? I have tried several times to get it to engage, I have also had that little part go into the speedo first then installing the cluster back and trying to get that to go back into the speedo cable but I've had no luck. Link to comment Share on other sites More sharing options...
vagabond Posted April 15, 2013 Share Posted April 15, 2013 sounds like your ready for another cable assembly Link to comment Share on other sites More sharing options...
Leo94 Posted April 17, 2013 Author Share Posted April 17, 2013 sounds like your ready for another cable assembly Link to comment Share on other sites More sharing options...
vagabond Posted April 17, 2013 Share Posted April 17, 2013 yeah I just changed the 1 on the 88 a couple of weeks ago, got itfrom the local pap Link to comment Share on other sites More sharing options...
