Belt tensioner bracket bent
patqx4
My belt tensioner bracket is bent down at the fork, making it impossible to get the belt tight enough. This resulted from my own buffoonery (tightening the belt with an impact wrench). Now when I try to turn the tightening bolt it slips off the fork! It looks like I can replace this bracket, can anyone help me find the part number?
An illustration to help my poor description: belts_zpsf46fb956.jpg
Thanks!
I "believe" its Bracket Idler Pulley 11926-4W00A. Hit up Rob (Alkorahil) and he should be able to get you a good price, or if you need it now I'd suggest a local junkyard
Diagram http://nissan4u.com/parts/pathfinder/us_r50/2002_10/type_42/body_electrical/compressor_compressor_mounting_and_fitting/illustration_2/
Edited by Trogdor636
Yep that is correct!
PART NUMBER: 11926-4W00A
DESCRIPTION: BRACKET-IDLER PULLY, 3.5L
$38.52 (NISSAN LIST: $70.47)
