Possible camber issue
Cory74700
So I want to crank up my torsion bars , and I'm sure that's not only gonna jack up my toe angle but I'm not sure if its gonna have an effect with my camber angle, I already have a bit too much positive camber which I can adjust myself but if it's too excessive what would be a good plan of recovery from this??
Measure your current ride height per the procedure in the FSM, see FA-52 here: http://www.nicoclub.com/FSM/pathfinder/1994_Pathfinder/fa.pdf
If the height is not correct, adjust the bars so it is, than have the front end aligned. If the shop you take it too says they can't align it, go somewhere else. If the height is set to spec there should not be any reason it can't be aligned. In fact when I had the alignment done on my 94 the alignment shop adjusted the bars before they did the alignment.
Edited by ahardb0dy
