uneven acceleration/throttle in 1995 Pathfinder
bf781
Hello!
I recently purchased a 1995 Nissan Pathfinder XE 4WD with 163k miles. Prepurchase inspection revealed it to be in good shape, no fault codes, no leaks or problems other than a small leak around oil sender sensor and a cracked front left CV joint boot.
In general, vehicle is running very well. However, I notice a slight, regular hesitation when accelerating, particularly on hills. It is very consistent and seems to happen around 2500 rpm (+/- a few hundred). Every 1.5-2 seconds, the engine sound drops slightly in frequency and it feels as if the throttle drops off for a fraction of a second. I don't see the tach noticeably drop down, but it feels like the engine is working, then drops a bit or encounters some resistance, working strong again, then hesitates for a bit, then works strong again, etc. It's pretty subtle but I can hear it slightly and also feel the resistance for a fraction of a second.
A fair number of forum posts mention rough idle or throttle and recommend various options: cleaning the MAF sensor, throttle body, fuel filter, air filter, intake manifold, idle air control valves, etc. However, few of those posts mention the power dropping off slightly in a very regular way with a frequency of every 1-2 seconds. Might this indicate some mistiming or misfiring with the coil/plugs/wires?
It's pretty minor right now, but I just want to correct in case it becomes a bigger problem later.
Any thoughts or advice would be appreciated -- thank you & Happy Holidays! :)
Sounds like it's related to one cylinder if it's that rhythmic, as in when that cylinder is supposed to fire it's not doing so fully. Injector, spark plug, wire, cap point, compression....
:shrug:
