pathy97 Posted December 19, 2012 Share Posted December 19, 2012 I just put 2 inch spacers on my pathfinder and I need longer than stock wheel studs. The stock length is 32mm in front 41.5 in rear. I need m12-1.25 studs but at least 50mm long. I cant find them anywhere. Can anyone help me out? Thanks Link to comment Share on other sites More sharing options...
Precise1 Posted December 21, 2012 Share Posted December 21, 2012 2" spacers would be 50.8mm and insane to run. What exactly are you running and asking information for? B Link to comment Share on other sites More sharing options...
pathy97 Posted December 21, 2012 Author Share Posted December 21, 2012 I found the wheel studs...btw there not insane many people are using them with no problems at all....2 inch is the max. Link to comment Share on other sites More sharing options...
nunya Posted December 21, 2012 Share Posted December 21, 2012 A 2" wheel spacer that's NOT a bolt on with its own new set of integrated studs? Check your lug torque religiously and often Link to comment Share on other sites More sharing options...
Precise1 Posted December 22, 2012 Share Posted December 22, 2012 I found the wheel studs...btw there not insane many people are using them with no problems at all....2 inch is the max. Ok, good luck... B Link to comment Share on other sites More sharing options...
devonianwalk Posted December 22, 2012 Share Posted December 22, 2012 Eeesh .. at least tell us they are steel and not aluminium. Link to comment Share on other sites More sharing options...
pathy97 Posted December 22, 2012 Author Share Posted December 22, 2012 Billet alum. Ive used them b4 with no problems. Torqued them to 100 ft lbs. I dont think they make them from steel they would be very heavy and tax the wheel bearing a lot. Link to comment Share on other sites More sharing options...
