1987caddy Posted November 4, 2012 Share Posted November 4, 2012 (edited) I did the 90 amp maxima alternator swap a few months ago and worked out good. Used my old belt that was a dayco 17370. Switched to gates brand belts and its too short. Does anyone know the correct part number for belt? They're saying 9361m but its too short. Edited November 4, 2012 by 1987caddy Link to comment Share on other sites More sharing options...
Trogdor636 Posted November 4, 2012 Share Posted November 4, 2012 The alternators are basically the same other than the internals and the belt pulley. My belt was tight getting it on, but it went. You've turned the adjuster bolt all the way in? Link to comment Share on other sites More sharing options...
1987caddy Posted November 4, 2012 Author Share Posted November 4, 2012 I took the adjuster completely out and the belt was still too short. Dayco and Gates show different lengths with the dayco being longer. I went with a 1 inch longer gates belt and the alternator is in the middle of adjuster so everything is back together Link to comment Share on other sites More sharing options...
Precise1 Posted November 5, 2012 Share Posted November 5, 2012 I was going to say that the old belt is probably just stretched, but it looks like you got it figured out. Do you recall the belt number? B Link to comment Share on other sites More sharing options...
1987caddy Posted November 5, 2012 Author Share Posted November 5, 2012 The belt was so tight, I had to take the fan off and put the fan pulley on the water pump. So I went with a Gates 9370. Gates site shows a 9361 but its too short Link to comment Share on other sites More sharing options...
