bushnut Posted October 22, 2012 Share Posted October 22, 2012 Found a coolant leak from what i think is a temperature censor on the throttle body. it's just under the air intake looks like it might be connected to cold start function? doesn't seem to be leaking much yet, just a few drops, but i think i should deal with this soon. I'll try and get a photo soon. just wondering what that part is called so i can find a new one. Link to comment Share on other sites More sharing options...
Towncivilian Posted October 23, 2012 Share Posted October 23, 2012 There are coolant lines running into the throttle body to prevent icing of the throttle body in very cold weather and to warm up incoming air to help atomize fuel better. Pull the hoses off and check if the fittings are rusted out. Also check for damage in the hoses themselves. Link to comment Share on other sites More sharing options...
bushnut Posted November 3, 2012 Author Share Posted November 3, 2012 so i figured out where the coolant is leaking from. It looks like it is called the "thermo element" for the fast idle cam it only leaks on start up until the engine warms up. it only leaks a few drops but it still concerns me. is this part expensive? and how hard is it to replace? thanks guys Link to comment Share on other sites More sharing options...
Towncivilian Posted November 3, 2012 Share Posted November 3, 2012 Is it this that's leaking? http://www.courtesyparts.com/16391u-element-kit-thermo-pathfinder-r50-1996-2004-p-196302.html Link to comment Share on other sites More sharing options...
devonianwalk Posted November 3, 2012 Share Posted November 3, 2012 $123? Good Lawd yo! Go to the local scrapper and pull one from an R50. Or, just keep adding coolant every other month. Link to comment Share on other sites More sharing options...
Precise1 Posted November 3, 2012 Share Posted November 3, 2012 Aren't there a few R50's being parted out right now? Figure out what years are compatable and hit up the Classified section... B Link to comment Share on other sites More sharing options...
bushnut Posted November 9, 2012 Author Share Posted November 9, 2012 (edited) this is the part that is leaking. top picture pointed at with screwdriver. I think the part # is 16391U at least on the diagram but nobody seams to have it. Edited November 9, 2012 by bushnut Link to comment Share on other sites More sharing options...
bushnut Posted November 16, 2012 Author Share Posted November 16, 2012 So I just brought Rusty in to have the timing belt replaced and I figured they could tackle this problem at the same time. they just called me and said that the screws holding it in are too corroded and they risk breaking it then requiring a new throttle body to the tune of $700.00. so I said just leave it. I'll deal with it in the spring. anybody have a used Throttle body for sale? Link to comment Share on other sites More sharing options...
Precise1 Posted November 16, 2012 Share Posted November 16, 2012 Are they saying that they can't remove or drill out a few corroded screws? I do appreciate that they didn't want to risk putting your vehicle out of commission but to say a broken screw=$700 part seems pretty lame to me. If it stops raining, I'll go out and take a look at our R50 to see what the big deal is. When the time comes, I'll walk you through dealing with them if it comes to that. B Link to comment Share on other sites More sharing options...
bushnut Posted November 16, 2012 Author Share Posted November 16, 2012 thanks I appreciate all the help. the leak is still only occurring on start up at cold temps (but seeing this is Canada and its only November, I've got 4 months of cold starts ahead of me.) I might just keep an eye on it and deal with it in the spring when I can work on it in the street. Link to comment Share on other sites More sharing options...
