Guest lauraP Posted December 15, 2004 Share Posted December 15, 2004 Hi I recently purchased a 95 Pathy. I was wondering about the rear windshield wiper. Is there a reservoir in the rear to fill it up or is it served from the front one. The front one is full but no fluid comes out for the rear windshield wiper. Thanks LauraP Link to comment Share on other sites More sharing options...
denisb Posted December 15, 2004 Share Posted December 15, 2004 My 94 has none in the back, it shares the front one. Check your front reservoir and see if you have two pumps on it. If it does, both are in the front. Link to comment Share on other sites More sharing options...
Guest lauraP Posted December 15, 2004 Share Posted December 15, 2004 Thanks alot Link to comment Share on other sites More sharing options...
n0cturne74 Posted December 16, 2004 Share Posted December 16, 2004 Since the washer fluid needs to travel from the front resevoir to the sprayer on your third brake light in the rear, you may have to work the pump for 10-15 seconds to get the fluid to travel back there. If I don't use mine for awhile it takes like 5 seconds for it to build up pressure in the line before it pours out. Hope this helps Link to comment Share on other sites More sharing options...
GrimGreg Posted December 17, 2004 Share Posted December 17, 2004 Since the washer fluid needs to travel from the front resevoir to the sprayer on your third brake light in the rear, you may have to work the pump for 10-15 seconds to get the fluid to travel back there. If I don't use mine for awhile it takes like 5 seconds for it to build up pressure in the line before it pours out. Hope this helps What he said. They both feed from the front. Link to comment Share on other sites More sharing options...
k9sar Posted December 17, 2004 Share Posted December 17, 2004 I concur. You could also doa little disassembly to get at the hose near the hatch and check to see if the nozzle is blocked by blowing it out. Good luck with it. Link to comment Share on other sites More sharing options...
