p51speed Posted September 15, 2012 Share Posted September 15, 2012 ok so the smog results good news is I passed WHEW! By rock_jock11 at 2012-09-14 anyway the bad is I passed by 1 point on the HC at 25mph and by 3 points on the 15 mph test , but my timing was at 9 degrees BTDC so my question here is . IS the high HC from the retarded timing as it was not burning off the fuel? so my transmission question is this , when I had to drill and retap and replace a broken stud on my exhaust manifold I removed the radiatior, ( I didn't know that tranismission fluid flow through the radiator) so I lost so fluid. I moved the truck today from back yard to front yard forgetting about the fluid loss, the transmission had a hard time going into gear , so I added 1 and 1/4 of ATF and now it will engage all the gears but it now seems like it engages gears while driving at a higher RPM then it did before the fluid loss from removing the radiator. mind you I only drove it from the back yard to the front yard ( about 60 feet) so my question is did i just not put enough fluid back in ? Link to comment Share on other sites More sharing options...
unccpathfinder Posted September 15, 2012 Share Posted September 15, 2012 Even with 0 fluid that far this wouldn't be a huge issue...prob a separate issue Link to comment Share on other sites More sharing options...
Kingman Posted September 15, 2012 Share Posted September 15, 2012 Uh. Check the dip stick, make sure it's full, and make sure the cooler lines aren't on backwards. Link to comment Share on other sites More sharing options...
p51speed Posted September 15, 2012 Author Share Posted September 15, 2012 the lines went back on just as they were when i pulled them off but im curious about how to check the levels every thing I research says check levels while truck is running , but the owners manual says to check while the engine is cool for at least 30 minutes after driving. which do I do ? Link to comment Share on other sites More sharing options...
Kingman Posted September 15, 2012 Share Posted September 15, 2012 Running in neutral after cycling through all the gears on level ground. Link to comment Share on other sites More sharing options...
p51speed Posted September 15, 2012 Author Share Posted September 15, 2012 ok thanks guys I will do that as soon as the sun comes up a bit more. Link to comment Share on other sites More sharing options...
Tungsten Posted September 15, 2012 Share Posted September 15, 2012 ok so the smog results good news is I passed WHEW! By rock_jock11 at 2012-09-14 anyway the bad is I passed by 1 point on the HC at 25mph and by 3 points on the 15 mph test , but my timing was at 9 degrees BTDC so my question here is . IS the high HC from the retarded timing as it was not burning off the fuel? so my transmission question is this , when I had to drill and retap and replace a broken stud on my exhaust manifold I removed the radiatior, ( I didn't know that tranismission fluid flow through the radiator) so I lost so fluid. I moved the truck today from back yard to front yard forgetting about the fluid loss, the transmission had a hard time going into gear , so I added 1 and 1/4 of ATF and now it will engage all the gears but it now seems like it engages gears while driving at a higher RPM then it did before the fluid loss from removing the radiator. mind you I only drove it from the back yard to the front yard ( about 60 feet) so my question is did i just not put enough fluid back in ? Yes, the timing should be at 15 BTDC for best results. How much fluid did you spill? If the transmission was not working when you removed the radiator, most of the fluid should still be inside the transmission. There is almost nothing inside the radiator when the engine is off and not turning the transmission. As long as you connected the lines back, you should be fine. Check the dip stick while the engine is running to see how much you need to add. Link to comment Share on other sites More sharing options...
p51speed Posted September 15, 2012 Author Share Posted September 15, 2012 did just that . check the levels while it was running and It was low. put more fluid in it and added some lucas transmission stuff to it , brought the level back up to where it should be . Link to comment Share on other sites More sharing options...
Tungsten Posted September 16, 2012 Share Posted September 16, 2012 You really don't want to mix any additives with ATF. That lucas stuff is mostly just good marketing. The ATF has plenty of detergents in it already and when you put in lucas stuff you are only modifying the original viscosity of the fluid. Link to comment Share on other sites More sharing options...
