erathge Posted September 6, 2012 Share Posted September 6, 2012 Hey guys, its almost time for new tires and I'm debating between the two sizes mentioned. I know that both sizes have been done by members so I guess I'm just wondering if anyone has any experiences to share. The less trimming (hopefully none) the better. The tires will be BFG All Terrains. Current size is 265/70/16. Specs of the vehicle: 2000 with 2" AC lift, 1" nx4 strut spacers, 15x8 pro comp wheels with 3.75" backspacing Thanks in advance for any information anyone can share. Link to comment Share on other sites More sharing options...
dududuckling Posted September 7, 2012 Share Posted September 7, 2012 (edited) I have 285/75/16 (or 32.8x11") Wrangler MTR on 3.75", 16x8 pro comp wheels. It also has 2" ac lift. When the rear flexes, the tire gets stuffed in and kicks the fender flare out. That's a guarantee. As for the front, during full turn, front tires rub the fender flares. Little trimming is required on the front fender flares around the bottom corner. You won't even notice when looking at it from the side. Since you have the NX spacer, you might not have to trim as much. Regarding tire-to-strut clearance, there's like 0.75-1" distance between them. I'm thinking on going with 305/70/16 (still a 32.8x12") next summer and see if it clears the struts. Edited September 7, 2012 by dududuckling Link to comment Share on other sites More sharing options...
captandy Posted September 7, 2012 Share Posted September 7, 2012 i love my bfgs 33x10.5x15 mimimal rub at full crank right hard turn.. Link to comment Share on other sites More sharing options...
AndyC Posted September 8, 2012 Share Posted September 8, 2012 On a 16" wheel you'd be looking at a 255/85R16. I've had great luck with that in a BFG MT. One thing, the tire absolutely no floatation. It will cut through a lot of mud or snow, but it's not staying on top of anything! Link to comment Share on other sites More sharing options...
erathge Posted September 8, 2012 Author Share Posted September 8, 2012 Sorry, I should have clarified. The wheels I'm going to be using are 15" pro comps, not the 16" stockers in the pictures. Thanks for the input so far! Captandy, your truck looks awesome, I'm just wondering how fender flares will affect rubbing if I go with the 33's Link to comment Share on other sites More sharing options...
captandy Posted September 8, 2012 Share Posted September 8, 2012 (edited) we have identical setups and im convinced rubbing on flares will not be an issue..could be wrong,i dont have flares, the tires get delivered http://www.discountt.../direct/home.do (by the way ihave ordered multiple tires and never had a better shopping experience than here..the staff is awesome and theres always a little extra discount when you ask nice) and when you see them you will have yourself convinced no way they will fit!!! then BAM!!!wow! a little triming,(I used a steak knife) the right hand crank rub is against the frame. Edited September 8, 2012 by captandy Link to comment Share on other sites More sharing options...
BowTied Posted September 13, 2012 Share Posted September 13, 2012 I don't know 2000s well, but I know the 01-04s sometimes have clearance issues to the calipers with 15" wheels. You maybe already knew that. Link to comment Share on other sites More sharing options...
erathge Posted September 13, 2012 Author Share Posted September 13, 2012 Yes, thanks for the reply, the shop I'm dealing with was able to do a test fit for me and it was tight, but there was enough room with the 15" wheel. So pretty much everyone agrees that a 33x10.5 will be better than a 32x11.5? Link to comment Share on other sites More sharing options...
captandy Posted September 13, 2012 Share Posted September 13, 2012 (edited) you know how i feel! Edited September 13, 2012 by captandy Link to comment Share on other sites More sharing options...
