Path88finder Posted August 25, 2012 Share Posted August 25, 2012 Hi everyone, It all started when I didnt drive my 88 Pathfinder for 3 days and the battery was flat the next time I went to drive it. After charging the battery I discovered using a multimeter that when the car is off there is 3 amps leaving the battery. I have pinned the problem on the alternator as when it is plugged in the meter shows 3 amps and when unplugged the meter reads almost 0 amps. If I unplug the alterntor every time the car is off and plug it back in again when driving the car the battery gets charged perfectly and doesnt loose charge when left for a few days. So I am guessing there is a problem with the alternator not cutting out when the car is off, or alternatively a problem with the cars wiring to the alternator plug. Is there a way of checking the wiring of the car or is the alternator more than likely the problem? If the alternator is the problem are there any alternators that I can buy with a higher amp output over the stock 50 amp one? Possibly from a later model Pathfinder? Link to comment Share on other sites More sharing options...
Kingman Posted August 25, 2012 Share Posted August 25, 2012 90-94 Maxima SOHC alternators are 90A. You'll need to swap the pulley over to your original v-belt from the poly-v, if they even sell you one with a pulley. Then make a little spacer if needed. Link to comment Share on other sites More sharing options...
Slartibartfast Posted August 25, 2012 Share Posted August 25, 2012 (edited) Does the Maxi alt fit the 2.4? Edited August 25, 2012 by Slartibartfast Link to comment Share on other sites More sharing options...
Path88finder Posted August 25, 2012 Author Share Posted August 25, 2012 Had a quick hunt around on eBay for the maxima alternator, is this the one you're talking about? http://www.ebay.com.au/itm/Nissan-Maxima-J30-VG30E-3-0L-Alternator-FREE-Digital-Multi-Meter-Included-/130730448546?_trksid=p3286.m7&_trkparms=algo%3DLVI%26itu%3DUCI%26otn%3D4%26po%3DLVI%26ps%3D63%26clkid%3D1584134737434454412&_qi=RTM839191 I also found an alternator from a 92 Pathfinder that has a v-type pully that looks like the mounts are the same that is 70 amp. Any ideas if this will fit? http://www.ebay.com.au/itm/ALTERNATOR-NISSAN-NAVARA-PATHFINDER-92-00-2-4LTR-PETROL-/130542958461?_trksid=p3286.m7&_trkparms=algo%3DLVI%26itu%3DUCI%26otn%3D4%26po%3DLVI%26ps%3D63%26clkid%3D1584201068125379263&_qi=RTM839190 Just to clarify that its a 2.4L z24 twin spark Petrol motor that the alternator needs to fit into. Link to comment Share on other sites More sharing options...
Kingman Posted August 25, 2012 Share Posted August 25, 2012 Same case as the Maxima alternators that why for the VG it's basically a direct swap with more amperage. Link to comment Share on other sites More sharing options...
Slartibartfast Posted August 26, 2012 Share Posted August 26, 2012 ^^My concern is that he doesn't have the VG, he's got the KA. Are the alternators the same between the VG and the KA? Link to comment Share on other sites More sharing options...
ahardb0dy Posted August 26, 2012 Share Posted August 26, 2012 The OP has an 88 which uses the older style alt with the fan on the outside, the only difference besides the amps between the 88 4 cyl. and 88 V6 alternators is the location of the plug. So any alt that we could swap over will work on his KA, as said already if a SOHC maxima alt is used the pulley would need to be swapped over. Link to comment Share on other sites More sharing options...
Tungsten Posted August 26, 2012 Share Posted August 26, 2012 (edited) The mounting holes of the alternators are the same between SOHC VG, KA, and NAPS-Z engines. Just get a 90A Maxima alternator and then a late WD21 Pathfinder V-belt pulley at your local wrecker and swap it on. If you can't get a pulley, then cut a piece of a pipe off and make a spacer with that for the older pulley. Edited August 26, 2012 by Tungsten Link to comment Share on other sites More sharing options...
