stioc Posted August 20, 2012 Share Posted August 20, 2012 My 2001 is 11 years old and as much as I'd love to replace every bit of it with newer parts it's just not feasible. So the next best thing is to fix/replace the weakest links. So far on my to-do list (stock 2001 Pathfinder SE 4x4): 1. Warn Hubs - done 2. Fluids (engine, transmission, diffs, transfer case) - done 3. OME springs - on order 4. KYB shocks - on order 5. New rear trailing arms - on order 6. Fuel filter - have to order still This is pretty much all I've done/intend-to-do to it. Is there anything else I may be overlooking? The radiator has a "08" sticker on it, assuming that's 2008 I'm probably ok there but should change the coolant and potentially the thermostat too? I have a clunk when getting on/off gas especially in 1st-2nd shift, could be the u-joint? Are these a common failure? What about the CVs? tie-rods? fuel-pump? Again in an ideal world I'd replace them all but for now if I could only concentrate on a couple of things my checkbook will be get a much needed break Link to comment Share on other sites More sharing options...
Towncivilian Posted August 20, 2012 Share Posted August 20, 2012 Grease the driveshafts every oil change (any NLGI #2 lithium soap base grease w/ molybdenum disulphide; Valvoline DuraBlend or SynPower is cheap and readily available), change out the brake fluid (DOT3 or DOT4 fluid only) & power steering fluid (use a turkey baster or suction gun for the PSF, use synthetic ATF as its replacement, do this a few times with a couple days of driving in between to exchange most of the fluid; recycle old PSF at any place that takes used oil). Yes, change the coolant and thermostat (use an OEM one). What color coolant is in the overflow reservoir? Just get a Wix 33023 or NAPA Gold 3023 for the fuel filter. Be sure to release fuel pressure by pulling the fuel pump fuse behind the coin tray and starting the engine, then waiting for it to die. Remove the spare tire to have more room for the change. Use a drain pan to catch gasoline that will come out of the fuel lines and old filter. The fuel pump isn't a preventative maintenance item. Link to comment Share on other sites More sharing options...
Heloflyboy Posted August 21, 2012 Share Posted August 21, 2012 This is more just common sense. Make sure your battery hold down is in place and tight. I was on the rubicon trail a couple weeks ago and a guys battery shorted out on his hood by bouncing around with no hold down. Could of happened to anyone. Link to comment Share on other sites More sharing options...
Der_Vier Posted August 21, 2012 Share Posted August 21, 2012 Water pump on my 98 broke at 153 miles, not sure if it was ever replaced prior to our ownership or not. Didnt go out on me wheeling but it would suck none the less. Preventative maintenance! Link to comment Share on other sites More sharing options...
stioc Posted August 21, 2012 Author Share Posted August 21, 2012 Grease the driveshafts every oil change (any NLGI #2 lithium soap base grease w/ molybdenum disulphide; Valvoline DuraBlend or SynPower is cheap and readily available), change out the brake fluid (DOT3 or DOT4 fluid only) & power steering fluid (use a turkey baster or suction gun for the PSF, use synthetic ATF as its replacement, do this a few times with a couple days of driving in between to exchange most of the fluid; recycle old PSF at any place that takes used oil). Yes, change the coolant and thermostat (use an OEM one). What color coolant is in the overflow reservoir? Just get a Wix 33023 or NAPA Gold 3023 for the fuel filter. Be sure to release fuel pressure by pulling the fuel pump fuse behind the coin tray and starting the engine, then waiting for it to die. Remove the spare tire to have more room for the change. Use a drain pan to catch gasoline that will come out of the fuel lines and old filter. The fuel pump isn't a preventative maintenance item. Thanks for the tips, will do! The coolant color is green. This is more just common sense. Make sure your battery hold down is in place and tight. I was on the rubicon trail a couple weeks ago and a guys battery shorted out on his hood by bouncing around with no hold down. Could of happened to anyone. Not a bad idea to check, thanks. Water pump on my 98 broke at 153 miles, not sure if it was ever replaced prior to our ownership or not. Didnt go out on me wheeling but it would suck none the less. Preventative maintenance! Ouch! Is the waterpump a big job i.e is it inside the timing chain cover or outside driven by the vbelts? Link to comment Share on other sites More sharing options...
rgallant Posted August 21, 2012 Share Posted August 21, 2012 (edited) Routine maintenance, just keep that up and if you hear or feel weird stuff get it checked out. I have literally a couple of 1000 of offroad KMs on my 97 and have had no major failures. But, make sure you have: a properly inflated spare, some duct tape, seals all self tapping screws A couple of small pieces of light wieght sheet metal spare oil With the stuff above you can wrap up a cut CV boot, seal a small hole in a fuel tank or oil pan, big problems are much harder to deal with and require a lot of gear. Have a sleeping bag and a couple of days of food and water and a small camping stove Lastly have a trip plan and make sure some one reliable has it. With all that in place you are pretty much ok. And go with good karma, stop to see if people who are broken down need a hand, can't hurt and it may work out for you if you break down. Edited August 21, 2012 by rgallant Link to comment Share on other sites More sharing options...
Towncivilian Posted August 21, 2012 Share Posted August 21, 2012 Go ahead and drain & fill the radiator with green coolant. It wouldn't hurt to replace the thermostat with an OEM one, but mine's factory and is still working just fine. Inspect your radiator cap following the instructions in this TSB and replace with a new OEM one if necessary. Link to comment Share on other sites More sharing options...
dirtymike Posted August 21, 2012 Share Posted August 21, 2012 put skid plates on your list. Link to comment Share on other sites More sharing options...
PaMountianbiker Posted August 21, 2012 Share Posted August 21, 2012 you should carry some spare tre's they are easy to bend and easy to replace on the trail. If you bend one on the trail and don't realize it chances are you will break a CV also . Link to comment Share on other sites More sharing options...
devonianwalk Posted August 21, 2012 Share Posted August 21, 2012 x2 on the tie rod end links. Here's my little encounter. Link to comment Share on other sites More sharing options...
theexbrit Posted August 22, 2012 Share Posted August 22, 2012 Ouch! Is the waterpump a big job i.e is it inside the timing chain cover or outside driven by the vbelts? It's under the plastic covers behind the belts. I did mine a couple of months ago & it's really not a big deal as long as you take the radiator out & hope that the crankshaft pulley nut comes undone without too much hassle. Link to comment Share on other sites More sharing options...
stioc Posted August 22, 2012 Author Share Posted August 22, 2012 Cool, thanks guys! Appreciate the input from you all. Link to comment Share on other sites More sharing options...
