Timmons Posted November 22, 2011 Share Posted November 22, 2011 I know some of you guys have removed the rear sway bar after the lift but i decided just to modify the links in the rear for more stability on the road. I cut the links in half, purchases a steel bar the same size and cut it to 6" inches. Inserted two sleeves and each side and welded the steel bar in between the halves. Here it is. Link to comment Share on other sites More sharing options...
nunya Posted November 22, 2011 Share Posted November 22, 2011 Shoulda made one into a quick disconnect while you were there! Link to comment Share on other sites More sharing options...
ramdala Posted November 23, 2011 Share Posted November 23, 2011 Wow those links looks big, how about the ride quiity?, any noticeable difference? Link to comment Share on other sites More sharing options...
Methfinder Posted November 25, 2011 Share Posted November 25, 2011 I took my front sway-bar off. I think my rear sway-bar is keeping my brake lines from tearing, so I'll leave it alone. Did you extend your brake lines in the back? Link to comment Share on other sites More sharing options...
Timmons Posted November 25, 2011 Author Share Posted November 25, 2011 I took my front sway-bar off. I think my rear sway-bar is keeping my brake lines from tearing, so I'll leave it alone. Did you extend your brake lines in the back? I removed the old brake lines in the front an rear and purchased extended steel braided brake lines. Works great. I also had to extend the breather hose connected to the rear diff. Maybe i should have welded on removable links for the rear sway bar, opps. I'm just removing the lower link when going out on the trails. Do you have an SFD? Link to comment Share on other sites More sharing options...
Methfinder Posted November 29, 2011 Share Posted November 29, 2011 I removed the old brake lines in the front an rear and purchased extended steel braided brake lines. Works great. I also had to extend the breather hose connected to the rear diff. Maybe i should have welded on removable links for the rear sway bar, opps. I'm just removing the lower link when going out on the trails. Do you have an SFD? yea, i just bought one. It should be here thursday. I ran a 3" lift for a year without it. It eventually tore the cv boots, but they were dry rotted anyway. Link to comment Share on other sites More sharing options...
