15x8 crager soft 8"s
captandy
ive got 16x8 with 4 inch backspace.... (even tho my rim is an inch bigger in diameter, the offset and width is the same) and ya like getabby said above, the rim is just about flush with the plastic fender flare.
i think the qx4 flare is just a tad bigger than the pathfinder flare.
captandy:
8" wheels with 4" backspacing will cause the tires to extend past the wheel wells on your Pathy, giving it a wider track, and making it appear "tougher". The downside is that the sides of your truck will get a lot dirtier, especially in mud.
Here's a photo of 31x10.50R15 BFG AT's mounted on 15x8 wheels with 4" backspacing on a 1997 LE:
12clearance_front.jpg?w=9892bc25
Click if image doesn't appear above
Edited by XPLORx4
