dfather99 Posted November 20, 2004 Share Posted November 20, 2004 would i be in trouble if i got to big of a cooler or is bigger better, i saw one for $33 26,000 gvw is that too much? :bow: Link to comment Share on other sites More sharing options...
dfather99 Posted November 20, 2004 Author Share Posted November 20, 2004 So I looked around the forum (which i promise i will start doing before posting), and i found out that bigger is better. but if you know somthing i don't let me know i just don't want to go too big. Link to comment Share on other sites More sharing options...
88pathoffroad Posted November 20, 2004 Share Posted November 20, 2004 Bigger is better. I have two 11x7.5x.5 tranny coolers installed on mine from a couple of junkyard Ford Exploders with the tow package. Cost me all of $5 each and ten minutes to get from the junkyard. Then, $5 worth of fuel hose, hose clamps, zipties and a bit of rubber (for spacing the coolers off the radiator) later, and I had dual coolers running just fine. Link to comment Share on other sites More sharing options...
dfather99 Posted December 3, 2004 Author Share Posted December 3, 2004 quick question does it matter wether the inlet and out on the cooler are on the same sides like this one tranny cool. or should it be where the inlet and out let are on the bottom on different sides. Link to comment Share on other sites More sharing options...
88pathoffroad Posted December 3, 2004 Share Posted December 3, 2004 Doesn't matter. The tranny fluid will flow through it no matter which way you mount it. Link to comment Share on other sites More sharing options...
