ahardb0dy Posted August 20, 2011 Share Posted August 20, 2011 Hello, my 90 sentra every 3 weeks or so I have to add brake fluid, the brake fluid in the reservoir will be down about an inch, I did have a bad wheel cylinder and I replaced it. Today I pulled the other rear wheel and brake drum to check to see if the other wheel cylinder was leaking and it is dry. Front brake pads are not low at all almost look brand new. No wet areas inside any of the wheels or near the master cylinder. Pulled the carpet up under the dash (drivers side) nothing wet there either. I guess I should pull the master cylinder off the brake booster to see if there is any fluid in it next. Brakes feel like they are fine and engine runs good also no white smoke or anything. Do not see any leaks on the ground anywhere under the car. Can't figure out where the brake fluid is going. Any ideas?? Thanks. Link to comment Share on other sites More sharing options...
Precise1 Posted August 20, 2011 Share Posted August 20, 2011 Sounds like you are checking everything that should be checked. I can only think of one other thing that I hope isn't the case, that you have a pinhole in one of the flex lines that only sprays fluid under pressure/when it bulges... B Link to comment Share on other sites More sharing options...
Tungsten Posted August 21, 2011 Share Posted August 21, 2011 Master cylinder is just bad. Link to comment Share on other sites More sharing options...
ahardb0dy Posted August 21, 2011 Author Share Posted August 21, 2011 (edited) pulled the master cylinder off the booster today, had my neighbor look at it ( he works at a local shop) he thinks the master cylinder is bad so I will be replacing it soon, fluid was low again today, thanks. Edited August 28, 2011 by ahardb0dy Link to comment Share on other sites More sharing options...
