u13turbo Posted June 16, 2011 Share Posted June 16, 2011 Awhile ago i chucked some 2" springs in, and reindexed torsions, the anchor for torsions was sitting low and one got bent abit, so today i reindexed again, aswel as bending the bent one straight, up into the crossmember, But now the front sits really low, i tried the next spline up and that made it sit to high... There is a little bit more room for cranking up so im hoping it will make enough difference. When i done the lift, i didnt worry about shocks. Currently i have one standard one and one aftermarket one, done by previous owner....... I can see that the side with the newer shock, sits quite abit higher, so im guessing my old standard one is shot? Im on a tight budget atm, still studying, so were would i get some ok shocks for a good price? in New Zealand. Cheers Link to comment Share on other sites More sharing options...
WarehouseRat Posted June 16, 2011 Share Posted June 16, 2011 ebay you can get a set of 4 procomp My link Link to comment Share on other sites More sharing options...
