Manual hubs
I just installed manual Warn hubs on the 92 Pathy......got them from Rugged Rocks.......three days and they were here!!!!!! Awesome shipping time!!!!!!!Simple install......However there were two bolts that didn't want to come out.....had to g3et a side grinder to grind the heads off........gonna test the new hubs tomorrow.....more to follow!!!!!!!!!!!!!!!!
no LSD for me.....looks like Lockright lockers for me.......comments?????? suggestions????? think that the lockright lockers will do the trick!!!!!!!
I like my lockright. I go through most mud in 2wd. I drive it to work often with no problems. Coasting around turns keeps it from being too noisy. It does change driveability some. It give you alot more drive line slack so you have to be easy on the clutch when shifting so it doesn't bang. It didn't take me long to adjust though.
James
