Check Engine Light
ChrisPerna
is that the order they were in?
I think this is right (though I don't have an R50)
P0463 Fuel Level Sensor
P0182 Fuel Tank Temperature Sensor
P0174 Fuel System Lean, Bank 2
P0420 TW (Two-Way) Catalyst System, Bank 1
Check fuel lines, make sure they're not cracked or worn. Is your gas gauge accurate? Sure it's not a bad batch of gas? Try getting some gas from a different station, and run some 91 octane fuel for a few tanks.
Edited by Towncivilian
Well since it's an 03 with the 3.5L you're supposed to run 91 octane all the time, but I don't think not doing it would cause the SES light to come on.
Sounds like you have a bad 02 sensor and maybe fuel gauge sending unit
