Going to the Mechanic - Help Me Not Get Screwed!
The Path is struggling to make it anywhere right now. It starts and drives but just barely. It's hard to describe but i'll do my best. The car starts up normally and for a brief period of time (1-3 minutes) seems to drive normally. However, after a short while, it hesitates and can only reach a certain speed. For example, I could floor it and maybe get to 45-55. It basically stops itself - I can let off the gas and the car will basically brake (the engine continues running but the car comes to a stop). It's as if the car is being a stubborn child who doesn't wanna do something but i'm the parent whos making it (best analogy I could come up with).
I've done a little research and came up with the following:
CEL light is not on, but I decided to check for codes anyway; came up with two:
P0325
P0325(pd)
Knock Sensor Malfunction
From what i've read this can be caused either by a short in the circuit or a faulty sensor.
From what I understood, there is a testing procedure in the FSM, but unless I can actually gain access to the sensor, I can't test either and of course the sensor is burried under the intake manifolds. Removing the manifolds is outside my realm of comfort for the time I could go without my daily driver and have decided not to tackle this and to take it to a mechanic.
I'm not a fan of this decision because of unfavorable experiences in the past but really have no other option. But I have a few questions first to make sure I don't get screwed over (too badly).
1. I read that the knock sensor malfunction is fairly common and for most is hardly noticable. In fact most people just clear it - this is definately not my case. Perhaps there is a deeper cause and the knock sensor is just a side affect? If so, do the symptoms above ring a bell to anyone? Or could it be possible that the knock sensor has gotten so bad that the engine has gone into some sort of "safe mode"?
2. I've done a bit of research on parts and labor, but i'd like to hear others input as well - what kind of damage am I looking at here?
Thanks in advance!
is it shifting when it's acting up? sounds like the trans is stickin in a lower gear (which will limit your speed and drag it down when not in the skinny pedal)
and welcome WAVEY
and welcome WAVEY
Forgive my ignorance, but how would I know?
The tachometer appears to be acting normally. I believe I remember seeing it get stuck at one point...
EDIT: Well now that I think about it, the tachometer does look to be pushing a little harder then it needs to be.
...and thanks! I've actually been lurking for quite some time, even tried to join a while back but never got my email! But here I am!
Edited by RonBurgundy
Fail safe mode perhaps? what if the light for the cel is out?
I'm not sure what fail safe mode would feel like, but if I had to guess - it feels likes this!
And yes.... chances are the CEL is out.
If the transmission was in failsafe mode, doesn't the O/D OFF indicator light flash for approximately 8 seconds after coming on for 2 seconds once the engine is started? If the transmission is in failsafe mode, it's locked in third gear.
EDIT:
Edited by Towncivilian
