ANDY Posted March 11, 2011 Share Posted March 11, 2011 hey i was searching really couldnt find anything about direct mounting a roof basket to the roof has anyone ever done it ? if so please say how you secured it from coming off the roof.(rivets,screws,bolts,etc). or anyway to mount a basket without railings any help would be appreciated thanks and if this has been covered sorry Link to comment Share on other sites More sharing options...
95responder Posted March 13, 2011 Share Posted March 13, 2011 im in the same bro what about xterra rack transplant like red i think Link to comment Share on other sites More sharing options...
ANDY Posted March 13, 2011 Author Share Posted March 13, 2011 i was thinking about that cause i like the way it looks but over here the junk yards are kinda whack they have nothing and i found a stock pathy roof rack but he wants 50 bucs so im trying to find ideas of just straight bolting to my roof Link to comment Share on other sites More sharing options...
JamesRich Posted March 13, 2011 Share Posted March 13, 2011 I mounted my xterra rack with threaded rivets from harbor freight. You just drill a hole with a unibit so you get a nice round hole then install the rivet, now you have threads. To direct mount a basket it would need to have some flat feet on it that you could bolt down. I think most baskets are made to mount to a rack. James Link to comment Share on other sites More sharing options...
95responder Posted March 13, 2011 Share Posted March 13, 2011 james wat about rust protect you go the silicon route. and i guess youll just have to fab up some flat feet for some other rack don't forget to think about how its supported on the roof and possible metal on metal chaffing. Link to comment Share on other sites More sharing options...
JamesRich Posted March 14, 2011 Share Posted March 14, 2011 james wat about rust protect you go the silicon route. and i guess youll just have to fab up some flat feet for some other rack don't forget to think about how its supported on the roof and possible metal on metal chaffing. I used a thread sealant for pipe threads. Silicone can burn through paint and cause rust. A window caulk would work too just read on the tube if it says it's safe for metal. James Link to comment Share on other sites More sharing options...
Meandmy92Pathy Posted March 14, 2011 Share Posted March 14, 2011 here is one from 4x4parts.com https://www.4x4parts.com/nissan/pathfinder-cargo-rack-with-mounts-p-4490.html I'm thinking about going with it...they want 365.00 plus shipping. Link to comment Share on other sites More sharing options...
Purec4 Posted January 9, 2012 Share Posted January 9, 2012 I picked up a square body S-10 4dr rack from a local junk yard for 20.00. The way it's built it can be shortend and narrowed to fit the raised rear portion of the roof. Or may see how it looks using it full length, once it stops raining! Also found instructions on building my own basket to fit what ever size roof rack I end up with. Link to comment Share on other sites More sharing options...
tmoore4512 Posted January 20, 2012 Share Posted January 20, 2012 I mounted my xterra rack with threaded rivets from harbor freight. You just drill a hole with a unibit so you get a nice round hole then install the rivet, now you have threads. To direct mount a basket it would need to have some flat feet on it that you could bolt down. I think most baskets are made to mount to a rack. James James, your rack looks amazing (wink) No seriously, I like the xterra rack on the wd21. I need to take a day off and go junkyard hopping.... here is one from 4x4parts.com https://www.4x4parts...nts-p-4490.html I'm thinking about going with it...they want 365.00 plus shipping. OUCH! Dude that is spendy... if your handy with a welder, just build you one! To each his own tho...and if you have that kind of green just laying around, more power to you! I picked up a square body S-10 4dr rack from a local junk yard for 20.00. The way it's built it can be shortend and narrowed to fit the raised rear portion of the roof. Or may see how it looks using it full length, once it stops raining! Also found instructions on building my own basket to fit what ever size roof rack I end up with. What part of TN man? Link to comment Share on other sites More sharing options...
