BLOWN Engine VG33E HELP!
linuxnut
I have a 1997 Pathfinder with a blown engine. Timming Belt broke at 3000 rpm. I went online a bought a JDM Engine VG33E from a Japan Importer. What will i need to get this engine up and running ASAP? I know that the engine harness wont work in an american car, so will i only need to change the electronics. Ex. Engine Harness, alternator,
If there is more that i need to change or advice i would appreaceate the help.
96 and 97 used one harness 98 and up used another i just used the upper intake and harness on my 97 donor engine where my truck was 98 there is an extra sensor or sumpthing i cant remember but there was an extra connector
Thanks madhornet. So you have done a JDM swap before?
