R50 Steering Stabilizer
shift220
This is what I had in mind for my truck... right now I have moog on it and they are solid. but we'll see if they break...
Tierod porn! :jig:
OT but are you planning on desining these for the R50? Moog's probably the best option otherwise.
Here are some better pictures of the setup. Not much to report, it's been on the backburner for the most part. Prototyping isn't pretty by the way...
It did get me started though. I know for sure that a bracket similar to the one I plasma cut out will be needed. Like I mentioned before, I may attempt to mount the shock on the bracket and somewhere on the knuckle.
What about taking a nut and screwing it on the inner tie rod past the outer tie rod that has a bolt welded to it to fasten the stabilizer so it is more secure in one spot and if you ever needed to change tie rods you could just put the nut on your new one....? You could make it a thick nut to be able to withstand the pressures being applied....
And as for the bracket you made, would it need some gusseting for people who do extreme offroading like myself?
Edited by muddfildvaynes
The clamp I am currently using uses 2 3/8" U-bolts to attach it to the tie rod. The unintentional effect of using a large, wide clamp like this is bracing the tie-rod and would make it much more resistant to bending. I don't mind the way I mounted it, it's just the fact that it twists the tierod everytime the shock cycles. I want to get it off the tierod all together.
Nope! Take a look at the stock bracket, it's made out of material less then 1/8" thick. I cut this out of 1/4" thick material. All the bracket really does is hold the sway bar in place.
I'm thinking a small bracket that would bolt underneath the tierod (using the tierod nut). I would just have to see where the shock ends up mounting to the subframe. Bringing it out and infront of that swaybar bracket would make things much easier for the install (notice how I don't have the boot on the shock :doh:). I also couldn't get one bolt in (backside of the swaybar bushing). Just little problems that can't be overlooked.
  • 10 months later...
I put this on the backburner for a while and the pathfinder is now daily driven by a close friend (I have a DD frontier for work). I'm glad this came up though because we are now setup with our cnc plasma table so these brackets I can rapid prototype and the rest is relatively easy..
I will get this going again!
If you were to put a soft rubber donut over the shock and in the void of the bracket, that would keep the shock centered, preventing the tie rod from rotating, yet still allow for some flex. Regards the mounting location, if anyone has access to a lathe, you could bore a pipe just big enough to sleeve the inner tie rod, yet leave the end 3/8" or so undersized. Thread that remaining 3/8" to thread on to your inner tie rod, and you have a sleeve/good solid mount to put your outer stabilizer mount....
Hey Muddfildvaynes,
What model stabilizer are you using and also where can I pick up the link for the inner tie rod? I just got done with my SFD and this has got to be a must for off-roading LOL. I wan't to install this over the weekend for sure.
Timmons,
I made the brackets and mounted the stabilizer. I would have to dig up what the stabilizer came off of.
The brackets were a one-off and they would need some R&D so I could produce them for the public. Same goes for the clamp on the tie-rod.
The biggest problem is that the install doesn't allow you to put the "rear" bolt into the subframe because the shock is in the way.
This will probably have to wait until spring, since my friend is using the Pathfinder as his winter beater.
Fleury's, what is the part number for that Moog inner tie rod?
I spoke with Fleurys last night....he's a "MetalHead" (He usually come out to see me when I'm in Montreal with what ever tour I'm working on.) The top pic is just a regular moog inner tierod, which he still has on his truck & in good condition. The lower is a beefier tierod he's been working on and will hopefully be ready to sell. Check out his website!
  • 11 months later...
