Front Fender Flare
LawDawg
Got the new AC lift kit, tires and wheels on got about 3" total. Should I cut the front of the front fender flare or try to massage it with a heat gun. Anyone ever use heat to move the front in and forward.
Thanks
OC
When I was running 35's on my 87 Hardbody I trimmed the flares slightly, they are real easy to cut, I just used a utility knife and cut the front edge to look the same as it did stock, be careful if you trim anything as the knife if sharp will go right thru the plastic and you don't want to have an "OOOPS" moment.
Had to remove and modify mud flaps. Tires rub front flare and that will also need modification as far as a "trim job" other then that everything came out great. Tire size was Wild Country's 265/75X16 = 31.6 in diameter.
