Der_Vier Posted December 14, 2010 Share Posted December 14, 2010 We (finally) got a light dusting today, which wasnt much, but enough for me to stick the 4wdhi on. Noticed whenever i slowly take a turn, there is resistance and a bumping going on in the front...put it in 2wd and its just the usual tire bump that I get. With the 4wd on the tire bump i get is increased. Can't imagine this is normal any ideaS? Link to comment Share on other sites More sharing options...
esy Posted December 14, 2010 Share Posted December 14, 2010 can you clarify what you mean by "tire bump"? if you mean binding, then that's pretty normal as that is what the transfer case is doing. it's sending power to the front axle, so the steering will feel a bit tighter than in 2WD. Link to comment Share on other sites More sharing options...
XPLORx4 Posted December 14, 2010 Share Posted December 14, 2010 What you're describing is normal when you turn sharp corners in 4WD on any high traction surface. A "light dusting" still allows the tires to find sufficient traction on the underlying pavement, so your steering will feel very heavy, and the tires will scrub as the drivetrain binding is periodically released. Link to comment Share on other sites More sharing options...
Der_Vier Posted December 14, 2010 Author Share Posted December 14, 2010 :coffee!: glad to know nothing is going to blow up many thanks As for the "tire bummp" if I go too quickly into a turn in 2wd when its dry out, feels like my tires in the front bump over something...not really badly but still noticeable. Im thinking it may just be because of the size of the vehicle and the force on the tires at that angle Link to comment Share on other sites More sharing options...
muddfildvaynes Posted December 14, 2010 Share Posted December 14, 2010 CV's are going bad? Link to comment Share on other sites More sharing options...
Der_Vier Posted December 14, 2010 Author Share Posted December 14, 2010 Hmm hnonestly I have no idea. How do I determine if they are? Cracked boots? it only makes the noise when going with some momentum into a sharp turn Link to comment Share on other sites More sharing options...
Pezzy Posted December 14, 2010 Share Posted December 14, 2010 I tend to agree with XPLORX4's suggestion. Try it again, on a day where you definitely feel you are losing traction in 2wd (rear end sways out on turns)... Link to comment Share on other sites More sharing options...
pathfounder Posted December 14, 2010 Share Posted December 14, 2010 Drive in a tight circle in an open area (parking lot) with the truck in 4WD. Take your foot off the gas. If the truck quickly groans to a halt, you have traction, and as the other guy said, the tires will scrub and hop to relieve the stress. Find a place where you really don't have traction and THEN you can worry about noises and shaking etc. Link to comment Share on other sites More sharing options...
