Manual trans fluid ammount/type?
zelix
i have read so much about this on these forums, however forgot most information.
I think i need GL-4 something something fluid, and have no idea how much i need in the trans. i heard the trans had a faulty fill point or something and you need to fill it more or something? getting my rig all back together tomorrow so direct help appreciated!
EDIT: also need to know the ammount of fluid that goes in the transfercase thanks!
Edited by zelix
Manual Transmission Oil (according to a TSB):
The fluid has to be filled 1.5 liters above the fill plug, for a capacity of 5.1 liters. The truck has to be tilted some or filled through the shifter opening. Don't use GL5.
Transfer (US quarts):
2-3/8
which I found pinnedHere in the 86.5-89 wd21 section :aok:
