Cannonball Posted December 13, 2010 Share Posted December 13, 2010 I'm looking for the OEM wheel spec's for a 2009 se 4x4 specifically the back spacing, center bore, and offset. im planning on using wheel adapters to convert from 6x114.3mm to 6x139.7mm which will be approximately 1.25" spacer. I'm trying to figure out what sort of offset and backspacing i'll need when i do this. thanks for your help! Link to comment Share on other sites More sharing options...
Alkorahil Posted December 30, 2010 Share Posted December 30, 2010 I'm looking for the OEM wheel spec's for a 2009 se 4x4 specifically the back spacing, center bore, and offset. im planning on using wheel adapters to convert from 6x114.3mm to 6x139.7mm which will be approximately 1.25" spacer. I'm trying to figure out what sort of offset and backspacing i'll need when i do this. thanks for your help! OFFSET = 30 Link to comment Share on other sites More sharing options...
