Nefarious Posted December 6, 2014 Share Posted December 6, 2014 Cool that's good to know. I want to adapt the maxima factory fan switch temp sensor as well to wire it up for low speed and a switch for high speed of I ever need it. Good to know it fits well. I don't mind a bit of trimming at all Link to comment Share on other sites More sharing options...
vagabond Posted December 7, 2014 Share Posted December 7, 2014 I used the temp sensor from the maxima and the threaded part it screwed into, I had to cut the threaded part out of the rad If you can find a TBI pathy take the metal tube from the upper rad hose remove the air vent from it and solder the threaded part in its place. Ive done this on my 88 and 94 and have had no heating problems, wired the low fan to the sensor and relay, hi speed fan is switched and relay. All the parts from pick a part except some wiring Link to comment Share on other sites More sharing options...
kidscollegefund Posted December 21, 2014 Share Posted December 21, 2014 Love my Spal fan, here in CA it rarely turns on only when AC running. All new cars/trucks have e-fans now... Link to comment Share on other sites More sharing options...
