Electric Fan Conversion with Poll
Tungsten
23 members have voted
  1. 1. Which is the better e-fan to run?
    • From a Nissan Maxima (J30)
    • From a Nissan Quest (V40)
    • From a Ford Taurus
    • Flexalite Black Magic
    • Other
Cool that's good to know. I want to adapt the maxima factory fan switch temp sensor as well to wire it up for low speed and a switch for high speed of I ever need it. Good to know it fits well. I don't mind a bit of trimming at all
I used the temp sensor from the maxima and the threaded part it screwed into, I had to cut the threaded part out of the rad
If you can find a TBI pathy take the metal tube from the upper rad hose remove the air vent from it and solder the threaded part in its place.
Ive done this on my 88 and 94 and have had no heating problems, wired the low fan to the sensor and relay, hi speed fan is switched and relay.
All the parts from pick a part except some wiring
