Guest MontanaPathy Posted October 21, 2004 Share Posted October 21, 2004 I have a 2000 Pathfinder SE 4x4...It has a lean to the driver's side, What could cause this? I used to have a 78 Land Cruiser, which also had a lean, but Land Cruisers are notorious for that...Seems to lean about 2 inches to the driver's side. Thanks folks Link to comment Share on other sites More sharing options...
Mark Posted October 21, 2004 Share Posted October 21, 2004 A few years use, will do that, sometimes. The springs get more wear on that side. There's always someone in the driver's seat, yeah? Link to comment Share on other sites More sharing options...
vengeful Posted October 21, 2004 Share Posted October 21, 2004 It could be almost anything. Worn springs Control Arms could cause it to lean. Unbalanced load? Does the truck lean the same amount all the time, or is it eggsagerated when the gas tank is full? Link to comment Share on other sites More sharing options...
joehurdler Posted October 24, 2004 Share Posted October 24, 2004 Ok, so I originally thought my 2003 Pathy LE had sagging on one side/corner; but then found out it was cause I was parked on a hill and all the gas in the gas tank was leaning towards my driver side rear which made it sag lower then all the other sides. Then as I parked it level, everything went back to normal. So yeah, try parking your car in a level place and see if you still have that problem. Or try parking your car the reverse direction you have it at now in that same spot, and see if it leans to the opposite direction. If it is, its just a matter of your gas tank putting weight towards one side based on the angle you're parked. Link to comment Share on other sites More sharing options...
Mr. Pickles Posted October 25, 2004 Share Posted October 25, 2004 Seams to lean, or does lean? Have you verified by comparing measurments for both sides, front and back? If not, go from the ground to the center of the wheel well, or another convenient and consistent spot. Could (hopefully) be a figment of your imagination, which I'm sure you'd prefer. Link to comment Share on other sites More sharing options...
Guest MontanaPathy Posted October 26, 2004 Share Posted October 26, 2004 Okay, on an empty tank, not so much lean...when full the lean is in full effect, about 2 inch difference on driver's side rear compared to pass...In my garage, it's not so noticable, but is still there...do i need new shocks? Link to comment Share on other sites More sharing options...
big_johnson Posted October 27, 2004 Share Posted October 27, 2004 Actually, beefier springs would be the best fix for that, shocks don't make any difference in height. Your spring options would be OME or AC Link to comment Share on other sites More sharing options...
lbinh Posted October 28, 2004 Share Posted October 28, 2004 Try this informative site. Pathies suffer from the front end lean. Dealer told me it was within factory specs. My '01 LE had a 1/4" to 1/2" sag on drivers side. http://members.cox.net/mainpages/index.htm Link to comment Share on other sites More sharing options...
