Rear door stuck jammed
Milos
Passanger side, rare door can not open.
Latch from outside seams loose, as it is not moving anything.
Inside latch seams that is moving okay, but still can not open.
Child safety can be reached with screwdriver, but still can not open.
I removed the panel, and there are two horizontal strong tubes, for locking/unlocking, both are moving.
I can not see a thing, as door is closed, and I did not have a small mirror.
How and from where should I approach it?
How to reach outside handle?
Is there any trick to open it from inside?
(not a big problem, but I tired telling people, please use the other door)
Maybe to get a sticker "use the other door, this one is locked" :)
Is it a door latch cable?
Found instructions here how to remove the panel (similar for rare one):
http://www.nissanpathfinders.net/forum/index.php?showtopic=27551&st=0&p=513889&hl=remove%20door&fromsearch=1entry513889
In what part of this manual can I find door:
http://www.nicoclub.com/FSM/pathfinder/1995_Pathfinder/
Edited by Milos
