Quest fans work!
Nissanfreak36
I was at the junkyard and happen to come across a very large fan on the front of a 1995-1997 nissan quest, i took it off costed me 10 bucks and bolted it to the front of my truck after i ran the fuse and the switch to the cab and the cooling difference is great. I had to cut the shroud a little bit to get past the steering box but it works and the fan has a large shroud connected to it for easy installation. If you have any questions just let me know.
I just ran it on a switch to the cab, I didnt put the fan clutch back in it but i did keep it just in case and it helps keep it cooler it you have an aluminum radiator and use to have a copper radiator ill get pics up soon for ya
