storage nets on back of front seats
ahardb0dy
Not a major tip here or anything but just found out how to tighten the nets on the back of the front seats and wanted to share. The nets on the back of my seats were sagging, just found if you pry the top of the plastic out on the top (either side) slightly the elastic string just has a knot on the end that sits inside of the plastic, so pull the elastic tight and tie a new knot in the elastic string, cut off the excess and reset the knotted end inside the plastic. It won't stretch as far as it would if you replaced the elastic string all together but now the nets sit tight and aren't drooping anymore.
