Exhaust Installation Problem
lyzic
Hi,
So I bought a bosal exhaust and bosal resonator to replace my rusted out stock stuff.
I got it taken off fairly easily, except for one problem which is mystifying.
Where I bolt the main exhaust on, just after the O2 sensors, there are 4 bolts. Are these bolts, or studs? Are they part of the original exhaust, or do they come off?
I had to cut one off flush, and none of them won't move. Won't even budge a little. They're so rusted I can't even tell if they had heads on them to fit a ratchet anymore.
I think I'll have to cut them out and put in bolts anyways, but looking for an answer so I know what I'm dealing with first.
Thanks!
they're studs, like lug nut studs. i dont recommend pounding them out, you can (in my case) shock the manifolds to the point of breaking. i just heated mine up and pressed them out. once theyre red hot, they move like nothings holding them in.
