ahardb0dy Posted May 12, 2010 Share Posted May 12, 2010 I filled my 94 pathfinder up last week at 185,868, got gas this morning and filled it up again at 186,131 which is 263 miles, but the odometer was saying I drove 291 miles, the truck took 17.1 gallons which is close to what it took last week (16.8), I think the speed sensor (not sure if that is the correct name for it) that runs the speedometer is not the correct one for this truck as the previous owner replaced the tranny and transfer case and the speedometer appears to be reading faster than the truck is running. Question is: if the speed sensor is not the correct part does the speedometer and the trip odometer both run off the same sensor?? I thought I drove 291 miles now after subtracting the starting and ending mileage and getting a different amount of miles I'm confused. Anyone have any idea on this please?? Thanks Link to comment Share on other sites More sharing options...
silverton Posted May 13, 2010 Share Posted May 13, 2010 As far as I've always known, the trip meter is physically linked to the odometer, which is ran by the speedometer cable. Link to comment Share on other sites More sharing options...
ahardb0dy Posted May 13, 2010 Author Share Posted May 13, 2010 no cable, it's electronic in mine Link to comment Share on other sites More sharing options...
Tungsten Posted May 13, 2010 Share Posted May 13, 2010 The trip odometers on Pathfinders from what I know are not physically linked to the odometer. They are electronic and they suck big time. Link to comment Share on other sites More sharing options...
ahardb0dy Posted May 13, 2010 Author Share Posted May 13, 2010 so the odometer would be more reliable than the trip odometer? Link to comment Share on other sites More sharing options...
ahardb0dy Posted May 14, 2010 Author Share Posted May 14, 2010 anyone know about this?? Link to comment Share on other sites More sharing options...
silverton Posted May 14, 2010 Share Posted May 14, 2010 I guess the odometer would be the most accurate reading. next time I fuel up I will compare my odometer to trip meter numbers. Link to comment Share on other sites More sharing options...
ahardb0dy Posted May 14, 2010 Author Share Posted May 14, 2010 ok, thanks Link to comment Share on other sites More sharing options...
Tungsten Posted May 14, 2010 Share Posted May 14, 2010 According to my GPS, the mechanical odometer is more precise. Link to comment Share on other sites More sharing options...
ahardb0dy Posted May 14, 2010 Author Share Posted May 14, 2010 (edited) ok, but in my case a 28 mile difference??? Does the speed sensor, this: what sends the signal to the speedometer?? I know my truck has 4.62 gears per the fender tag, it is a "SE" and came with and still has 31" tires on it. I also know some pathfinders have a 4.37 gear ratio were any other ratios available in the pathfinder or 4WD pickups? I can tell my speedometer is running high but can't see the speed sensor making such a big difference in the speed. is the above pic what the sensor looks like? as the FSM shows this: Edited May 14, 2010 by ahardb0dy Link to comment Share on other sites More sharing options...
ahardb0dy Posted May 14, 2010 Author Share Posted May 14, 2010 Ok, drove the pathfinder to work this morning, switched the trip odometer over to "B" and waited until the odometer hit the next number than reset the trip odometer. watched both as I drove exactly 1 mile, they are both running exactly the same. Kept an eye on it as I drove into work and they still stayed exactly the same. So I guess I must have read the mileage wrong last week. I still think the speedometer is running faster and am going to check that on the way home from work tonight. Thanks Link to comment Share on other sites More sharing options...
ahardb0dy Posted May 14, 2010 Author Share Posted May 14, 2010 checked the speedometer tonight on the way home from work against my buddies Toyota Tacoma and it was exactly what his was reading so I guess it's correct after all, may just be that I'm not used to driving the pathfinder it has been a long time since I drove the hardbody I used to own, ok check that off the list, next... Link to comment Share on other sites More sharing options...
