Got A New Noise
ahardb0dy
94 pathfinder, I notice when I am slowing down to come to a complete stop I hear a noise sounds almost like something hitting the floor from underneath, I don't think anything is, sounds like it's coming from the pass. side, I want to say it may be the rotor moving slightly on the studs but not sure. Anyone ever hear something like this and know what it may be??
check your suspension link bushings, lug nuts, caliper mounting bolts, exhaust hangers, gas tank supports, compression rod bushings. The rotor shouldn't move if the wheel is tight. It could be many things
My first too guesses are compression rod bushings and make sure your uca's are tight. I say that because it happened to me, lost a shim and it was shifting everytime I would come to a stop due to the bolt no longer being "tight".
