knocking noise from passenger front.
jroddvette
hey guys,
i am getting a knocking noise from the passenger front suspension.
it happens when i go over uneven ground, and it sounds like something is swinging around under the truck. i can also get it to make the noise by pushing on the front passenger fender.
i have gotten under the truck and had someone push on the fender to see if i could find the problem, and i think it is the front strut.
has anyone else had this problem?
have you replaced the sway link yet? Its a vertical link that parallels the strut, and the bushings wear out which makes a klunking noise. grab it and see if it has play. they're cheap - 30 or 40$.
m.
I brought my car to Nissan this morning to get a free 100 point inspection (lets see how many things they want me to fix :contract: )
Anyway, the real point of this post is to tell you that the popping noise I'm hearing was coming from the Right front sway bar. Hopefully this is your problem too.
~Jason
well, i checked my sway bar link and there was play in it.
i replaced it and the noise is gone. B)
but, it was a b*tch of a job.
i had to cut the old one off with a cutting wheel.
i hope this info helps you guys.
thanks for your help!
jared.
the swaybar and the end links are different.
the links are at each end of the swaybar. they run vertically and connect to a bracket on the strut.
take a look and you will see what i mean.
if you can have someone push on the front of your truck to make the clunk, then hold the end link and see if that is the problem.
jared
